Ummmm.....why do you need to?
Don't mess with system.ini unless you know what you are doing!
heres a snippet from my system.ini file. How can i find out which programs these link to? i need to get rid of some of them.[386Enh]
device=C:\WINDOWS\SYSTEM\dva.386
device=*vshare
ebios=*ebios
device=*vshare
device=*dynapage
device=*vcd
device=*vpd
device=*int13
www.162Dev.com
"DO YOU KNOW HOW TO SPELL? I AM NOT AN ELEPHANT!!! " -YUPAPA
"You can be a corn! BUT Can I eat you?" - YUPAPA
Delete all of them, they are useless
.... that was a joke btw![]()
"I cut my wrists, you feel them bleeding, just like a parasite you creeping, suffer like the ----ing crucifixion, cover me with dirt, there won't be no resurrection"
i know what im doing, i've done it before. Now for some reason its using abbreviations for file paths. I need to get rid of some of the crap programs that mess up my memory on startup that i dont need. I know you need Explorer, systray, smreminder and rnaapp, i wouldnt be dumb enough to delete those.Originally posted by Jan
www.162Dev.com
Go to Start > Run > and type 'msconfig' > OK
Thanks ManOriginally posted by Akalon
www.162Dev.com
Yeah, also delete the autoexec.bat file... it is a virus and is useless aswell.![]()
And config.sys. We all know that HIMEM.SYS is an extremely contagious virus.
Akalon, if only there was MSCONFIG for Win2000, I have to do it manually.![]()
the poster formerly known as needcgispace - NOTHING!
Obsidian Hosting Networks - Head Admin - Changing the way you play the game.
URL: http://www.obhost.net/
IRC: irc.gamesurge.net/obhost
lol what are you on about?
www.162Dev.com
Oh, and while im here i my aswell ask a few more questions.
What on earth is the program "mdm" and which programs (excluding "explorer") do you need in the memory to successfully run windows... ie w/o cracshing.
www.162Dev.com
Hayama, just curious but would this work?
http://lightning.prohosting.com/~gcis/MSCONFIG.EXE
i think all you need is explorer.exeOriginally posted by coldturkey
is that possible to use that on win2k?
YES, it is. I got it yesterday when I was tweaking my Win2k install. I just stuck it in my windows folder, and now I can get to it by typing msconfig in run. Easy. Now, if I can get winipcfg.exe...
what does winipcfg.exe do?
and if you really need it extract it from a win98 cd or something![]()
Tells you your ip addy, start > run > winipcfgOriginally posted by is0lized
www.162Dev.com
