Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Bandwidth Monitoring Script?
    JSHosts.com [JSH]John is a glorious beacon of light[JSH]John is a glorious beacon of light[JSH]John is a glorious beacon of light[JSH]John is a glorious beacon of light[JSH]John is a glorious beacon of light[JSH]John is a glorious beacon of light [JSH]John's Avatar
    Aug 2005
    Newcastle, UK
    1,957
    I'm just wondering but do any of you know of a php script that is capable of showing the bandwidth usage of a site?
    I have a future customer that is being hosted elsewhere where they have no cPanel and no stats scripts installed so I'm looking for a one where I could check the bandwidth usage per week or month.
    JSHosts - UK Web Hosting
    Web Hosting | Reseller Hosting | OpenVZ VPS | Xen VPS
    cPanel | Softaculous | CloudLinux | CloudFlare | R1Soft Backups
    I love you! Yellowmc will become famous soon enough Yellowmc's Avatar
    May 2005
    Birmingham, UK
    1,923
    awstats?
    HostPing - Shared Hosting/Virtual Servers/Dedicated Servers
    Premium Quality Hosting based in the UK!
    Aug 2005
    Newcastle, UK
    1,957
    I've tried to install awstats on the server but doesn't seem to work, I'll give it another go in a sec
    Member Robert is a glorious beacon of lightRobert is a glorious beacon of lightRobert is a glorious beacon of lightRobert is a glorious beacon of lightRobert is a glorious beacon of lightRobert is a glorious beacon of light Robert's Avatar
    Oct 2000
    Kendall, FL
    5,834
    Does it give you an error message?
    YourIP.us - Check your IP
    Checksite.us - Check if a site is down or not
    ReverseIP.us - Check how many sites are hosted on the same server.
    Aug 2005
    Newcastle, UK
    1,957
    I get "Error 403 - Forbidden" but just reading the installation guide there and I would need access to the server they're on but since it's a web host I doubt it's possible so I just need to find some other script similar that can read apaches log file and show how much bandwidth etc is being used...
    Yours Truly .Joe. is an unknown quantity at this point .Joe.'s Avatar
    Mar 2006
    The Unknown
    1,222
    I'm pretty sure your bandwidth monitor should be in the "awstats", wouldn't know why it's not working though. Ask your host, maybe it's a glitch or something.
    Aug 2005
    Newcastle, UK
    1,957
    I think you would need to read from the top post down to here I said on my first post it's for a future customer, they just need to know how much bandwidth they currently use and their current host doesn't have any sort of cPanel or bandwidth monitoring scripts in place.
    Mar 2006
    The Unknown
    1,222
    Then tell your clients to view their awstats? or can't they just view the cPanel navigation strip on the left to see how much bandwidth they've currently used up?
  9. #9
    Aug 2005
    Newcastle, UK
    1,957
    How can they view their awstats if they don't have awstats or cPanel installed on their hosts server?
  10. #10
    there is also mrtg as well www.mrtg.org if you are looking something to use that is more precise
    Avail Networks, LLC Version 2.0 Coming Soon!
    Fully Managed Dedicated Servers
    Premium H-Sphere 2.5 Hosting
    Bringing Local Service Nationwide
  11. #11
    Mar 2006
    The Unknown
    1,222
    Quote Originally Posted by [JSH]John
    Oh now I know what you're saying. So the awstats isn't available for them. Hmm, well if you're the root WHM, can't you fix that?
  12. #12
    Aug 2005
    Newcastle, UK
    1,957
    Chief, you didn't read the first post did you? I'm not their current host, they just want to be able to check how much bandwidth is being used atm because it's a popular site then they can choose a plan.
    Just had a look at mrtg and seems like I would need access to the server via ssh to compile etc, they're just on normal shared hosting, thanks though
  13. #13
    usually mrtg is something web hosts install anyway on their machines. I believe there is a way to configure it to run on a separate site as well as the main machine, have your guy see if the current host can set him up
  14. #14
    Aug 2005
    Newcastle, UK
    1,957
    The customer contacted their host but they won't give out the bandwidth usage for some reason so we're going to host them and see how much bandwidth they use per month. Thanks for the help guys
  15. #15
    now that is just plain weird, no wonder he wants to move
