Is your php working? what does phpinfo say? is that file an html or php file?
Hi mates,
well i buyed a dedicated server a few days back which has windows server 2003 enterprise edition installed on it. I access it by remote desktop. I need some help figuring out the SMTP and sendmail things. I have installed WAMP5 on my server. and i installed PostCast Professional Server (smtp) which is working fine and port 25 is also not blocked and working, i checked by telnet. In my php.ini file ... at the smtp settings place i have write my ip instead of localhost ....... I have also installed argosmail server on my server. To test my Smtp server i am running a PHP mailer script ... check out this picture how it appears on my server :
Now the same script uploaded on other host :
Please i want to fix it all to make my server working perfect and SMTP and sendmail also...!
Any help in this regard would be great !
To Catch Me, U Gotta Be Fast, To Find me, U Gotta Be Smart, But to be me !!! ... Dammnn...U Must be Kidding...!
-W
Yes boss, i think the php is working fine, here are some details i found related to smtp and sendmail in phpinfo()
sendmail_from you@yourdomain you@yourdomain
sendmail_path no value no value
serialize_precision 100 100
short_open_tag Off Off
SMTP localhost localhost
smtp_port 25 25
PHP Version 5.2.0
See, the problem is not with sendmail at this point.
It should not output the php code in that form, but the $subject var.
Is that file a .php file or .html file or what
try replacing <? print $subject; ?> with <?php print $subject; ?> in that file's source
see if it still displays the code or the box is empty
-W
