Results 1 to 8 of 8
Thread: PHP Help
    b& Zombie has a reputation beyond reputeZombie has a reputation beyond reputeZombie has a reputation beyond reputeZombie has a reputation beyond reputeZombie has a reputation beyond reputeZombie has a reputation beyond reputeZombie has a reputation beyond reputeZombie has a reputation beyond reputeZombie has a reputation beyond reputeZombie has a reputation beyond reputeZombie has a reputation beyond repute
    Mar 2007
    Florida
    1,985
    PHP Help
    Alright this is from my game i am having a major problem with it
    AP Box
    Rules:
    No more than u have
    No neg numbers
    PHP Code:
    if ($amount >= $stat[ap])
    print
    "You cannot use more than you have";
    exit;
    It will use all the AP but u cant use all u always have to have 1 remaining the script wont allow u to use it all?
    Any ideas
    Super Moderator#1 stuffradio has a reputation beyond reputestuffradio has a reputation beyond reputestuffradio has a reputation beyond reputestuffradio has a reputation beyond reputestuffradio has a reputation beyond reputestuffradio has a reputation beyond reputestuffradio has a reputation beyond reputestuffradio has a reputation beyond reputestuffradio has a reputation beyond reputestuffradio has a reputation beyond reputestuffradio has a reputation beyond repute stuffradio's Avatar
    Oct 2005
    BC, Canada
    7,300
    PHP Code:
    if (is_numeric($amount) > $stat[ap]) {
    echo
    "You can't use more than you have";
    exit;
    } elseif (
    is_numeric($amount) && $amount 0) {
    // code here
    stop staring krakjoe is a splendid one to beholdkrakjoe is a splendid one to beholdkrakjoe is a splendid one to beholdkrakjoe is a splendid one to beholdkrakjoe is a splendid one to beholdkrakjoe is a splendid one to beholdkrakjoe is a splendid one to beholdkrakjoe is a splendid one to beholdkrakjoe is a splendid one to behold krakjoe's Avatar
    May 2006
    UK
    3,616
    is_numeric returns a boolean value, so not quite ...
    PHP Code:
    <?php
    if( $amount >= $stat['ap'] )
        print(
    "You cannot use more than you have" );
        exit;
    elseif(
    $amount )
        print(
    "You cannot use negative numbers" );
        exit;
    elseif( (
    $stat['ap'] - $amount ) < )
        print(
    "You must leave at least 1" );
        exit;
    else
    // Code here ...
    (\__/) Joe Watkins
    (='.'=) Software Architect
    (")_(") http://pthreads.org
    Copy and paste bunny into your sig, help him gain world domination.
    Mar 2007
    Florida
    1,985
    ty krakjoe but you might have mis understood due to my lack of elaberation and proper explanation
    the problem is
    AP: 3 [USE]
    when they type in 3 to use it in the ap box it wont allow it it only allows the most to be all but 1 it wont allow all to be used that is my problem
    May 2006
    UK
    3,616
    I still don't get it, I was just guessing and fixing what stuff posted ...
    (\__/) Joe Watkins
    Junior Member TheXianProject is an unknown quantity at this point
    Feb 2006
    Hawaii
    6
    Quote Originally Posted by krakjoe View Post
    I second that, I don't understand what you are asking for either Rsmiley.
    Mar 2007
    Florida
    1,985
    Once my server goes back online i will allow u to see the error
    Mar 2007
    Florida
    1,985
    shadowofdemise.uni.cc
    Join and goto Overview -> AP and try to use all 3 points u have and then try 2
