Results 1 to 9 of 9
Thread: Sister's PC. No Sound
    Bullah Dan has much to be proud ofDan has much to be proud ofDan has much to be proud ofDan has much to be proud ofDan has much to be proud ofDan has much to be proud ofDan has much to be proud ofDan has much to be proud ofDan has much to be proud of Dan's Avatar
    Mar 2005
    Bendigo, VIC, Australia
    6,957
    Exclamation Sister's PC. No Sound
    My sister's PC has no sound so need assistance.
    Here is a screeny of the motherboard.
    Anyone have ideas?
    http://www.danriordan.net/pics/motherboard.JPG
    Cheers
    Dan O'Riordan
    Author of 'The Everyday Idiot's Guide to Web Hosting'.
    JSHosts.com [JSH]John is a glorious beacon of light[JSH]John is a glorious beacon of light[JSH]John is a glorious beacon of light[JSH]John is a glorious beacon of light[JSH]John is a glorious beacon of light[JSH]John is a glorious beacon of light [JSH]John's Avatar
    Aug 2005
    Newcastle, UK
    1,957
    If you could open up the PC then take a look at the motherboard, try and find the make and model number. Once you have atleast those, I'll be able to try and find you some sound drivers. Hopefully it will be on there.
    JSHosts - UK Web Hosting
    Web Hosting | Reseller Hosting | OpenVZ VPS | Xen VPS
    cPanel | Softaculous | CloudLinux | CloudFlare | R1Soft Backups
    Mar 2005
    6,957
    Well bud,
    Can't find the info for you.
    All I can tell you is that the PC is P4
    CHPSET: ATI RS400
    Dan O'Riordan
    GO HABS GO Corazu is just really niceCorazu is just really niceCorazu is just really niceCorazu is just really niceCorazu is just really nice Corazu's Avatar
    Dec 2003
    Richmond Hill, Ontario
    1,360
    Are the speakers plugged in?
    Corazu
    Mar 2005
    6,957
    Quote Originally Posted by Corazu View Post
    YoU think I am stupid?
    Make iQON
    Model Number: PSP-525PP
    Dan O'Riordan
    Mar 2005
    6,957
    Thanks Bud.
    Will try that tomorrow when I go back to my Sister's place.
    Dan O'Riordan
    Blitzkrieg Bopin' Dini is a glorious beacon of lightDini is a glorious beacon of lightDini is a glorious beacon of lightDini is a glorious beacon of lightDini is a glorious beacon of lightDini is a glorious beacon of light Dini's Avatar
    Nov 2004
    localhost
    1,434
    Considering you last posts in this section Dan, I have these sugestions for you:
    - Plug your Speakers
    - Connect the Speakers to the PC (on the green hole, not the pink or the blue one)
    - Raise the volume on the "Volume Control" app.
    if none of the following work:
    - Call an unexpirienced basic user to fix it for you
    Just joking!
    On topic: did it stop working suddenly or after a format or something?
    Alfredo Mella
    +1-530-346-4007
    vomit free since 93'
  9. #9
    It gets better. Dynash has a brilliant futureDynash has a brilliant futureDynash has a brilliant futureDynash has a brilliant futureDynash has a brilliant futureDynash has a brilliant futureDynash has a brilliant futureDynash has a brilliant futureDynash has a brilliant futureDynash has a brilliant futureDynash has a brilliant future
    Jan 2008
    United Kingdom
    4,531
    have you made sure the card isn't just broke? or loose?
    JavaKrypt
    "If you think education is expensive. You should see the cost of ignorance."
Similar Threads
  1. how does this sound
    By socialreject in forum Free hosting requests
    Last Post: September 21st, 2002, 03:52
  2. Sound
    By Ben in forum Computers
    Last Post: September 2nd, 2002, 00:24
  3. i need help with sound
    By crj in forum Webdesign / HTML
    Last Post: January 15th, 2002, 05:02
