You can, by using partition apps, but it's not always possible that it will work. You could damage the current partition tables and end up deleting/corrupted the files that you have on the disk.
Try things like Norton Partition Magic, GParted etc.
I have an 1000GB hard drive that has been split into to partitions: C:
and D:. C: has about 150GB and D: has about 840GB. And want to know if its possible to add more space from the D drive to the C drive? Otherwise all that space will sorta be wasted :/
I aint the best at computers but i heard that a few friends have done it but wont tell me lol
Using Windows Vista x64 bit if that helps any![]()
Vista's partition manager is crap.
Before using gparted, make sure you backup
My Blog: www.talkcomputer.net
There is a freeware too for the same purpose. It's called Ranish partition manager. But if you need an easy way, better to go with Norton's Partion Magic.
Partition Magic works for me every time
'buy' it.
JR WEBHOST :: Web Hosting - Web Design Indonesia
Office : Pusat Niaga Puri Agung, Lt 1 Blok 1-06, Cengkareng, Jakarta Barat, Indonesia,+62 21 54381081,+62081809324678,YM : flexserut Live Chat
Server : Colocation at Cyber Building Data Centre, Jakarta Indonesia
Use this one: http://www.partition-tool.com/personal.htm
Its free.![]()
