Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Skype problems
    Junior Member Christofen is an unknown quantity at this point
    Mar 2012
    2
    Skype problems
    I can enter my skype account! As soon as I enterskype it shuts down. i have tried everything I could do, I even restored the sytem! What can the problem be in?
    Pro Member deanhills is a glorious beacon of lightdeanhills is a glorious beacon of lightdeanhills is a glorious beacon of lightdeanhills is a glorious beacon of lightdeanhills is a glorious beacon of lightdeanhills is a glorious beacon of light deanhills's Avatar
    Aug 2009
    371
    Have you flushed your DNS?
    run> cmd> ipconfig/flushdns
    Do it twice.
    I'd also delete all cookies and temporary files in the browser you are using. Then log out and shut down your computer, wait a few minutes and log back in.
    b& cassiejmiller is on a distinguished road
    Oct 2011
    107
    Try un-installing then installing again if it will work.
    -Team WebLyte- WL-Michael is a jewel in the roughWL-Michael is a jewel in the rough WL-Michael's Avatar
    Jan 2005
    Jacksonville, FL
    1,604
    Try uninstalling Skype and installing the latest version.
    You may also want to try the following:
    Please do a Skype reset:
    1. Ensure that "Show hidden files and folders" is switched on.
    Click Start and then Run Type "control folders" and click OK. In the View tab, ensure that Show hidden files and folders is enabled
    2. Exit Skype : From the system tray >> right click on the skype icon and click "Quit Skype"
    3. Click Start >> Run Type: %appdata% Rename folder "Skype" to "Old_Skype".
    4. Re-run Skype
    Mar 2012
    2
    Thnaks, the last advice worked!
    Junior Member jsholman is an unknown quantity at this point
    Mar 2012
    16
    I also had similar problem, because of Skype plugins... Uninstall and install it once more (But!!! The newest version!)
    Junior Member John_M is an unknown quantity at this point
    Mar 2012
    17
    That's weird, I have never had any problems with Skype, hopefully I didn't just jinx it. Glad you got it solved.
    Junior Member Sara Veron is an unknown quantity at this point
    Apr 2012
    Australia
    15
    Thank you, I was facing the same problem and this helped.
    Quote Originally Posted by WL-Michael View Post
    4. Re-run Skype
  9. #9
    Skype problems
    Hi,
    I came across the same problem as this is. So what I did was I deleted the temp files for skype present in program files.
    Thanks
  10. #10
    Junior Member pwhjenny is an unknown quantity at this point
    Jun 2012
    10
    Hello,
    I've tried the same and it fixed my issue also.
    Thank you.
  11. #11
    Member steven peter is an unknown quantity at this point
    Jun 2012
    53
    You can use any other software also like the spark .
  12. #12
    Member Deem Host is an unknown quantity at this point
    Jul 2012
    45
    Skype problems
    I am getting same problem from skype,please help me out guys.
  13. #13
    Junior Member annex212 is an unknown quantity at this point
    Sep 2012
    1
    skype history
    any one can tell e how can i delete my whole Skype history??? from cookies also??
  14. #14
    JSHosts.com [JSH]John is a glorious beacon of light[JSH]John is a glorious beacon of light[JSH]John is a glorious beacon of light[JSH]John is a glorious beacon of light[JSH]John is a glorious beacon of light[JSH]John is a glorious beacon of light [JSH]John's Avatar
    Aug 2005
    Newcastle, UK
    1,957
    Windows
    How do I delete my conversation history?
    It is not possible to delete individual conversations on Skype. However, you can delete your entire conversation history. This removes your entire history, which includes:
    • Instant messages
    • Calls
    • Voice messages
    • Text messages
    • Sent and received files
    When your conversation history has been deleted, it can’t be recovered.
    To delete your conversation history:
    1. Sign in to Skype.
    2. In the menu bar, click Skype then Privacy…
    3. Under Keep history for, click Clear history.
    Ref: https://support.skype.com/en/faq/FA3...i-do-with-it#8
    JSHosts - UK Web Hosting
    Web Hosting | Reseller Hosting | OpenVZ VPS | Xen VPS
    cPanel | Softaculous | CloudLinux | CloudFlare | R1Soft Backups
  15. #15
    Member ForzaHost has a spectacular aura about
    Jun 2010
    43
    AppData can always be the one that catches people out as to the untrained eye, it's hidden and never to be seen.
    ForzaHost | Now with Window's Licenses!
    Support that stands out from the rest.
    Cloud Powered, Blazing Fast, Feature Packed Hosting.
    Check us out: Shared, Reseller, VPS and Dedicated Hosting.
Similar Threads
  1. Skype
    By GeorgeB in forum General Discussions
    Last Post: October 7th, 2010, 05:10
  2. skype support
    By tlchosting in forum Host Talk
    Last Post: February 20th, 2009, 02:02
  3. skype anyone?
    By iBrightDev in forum General Discussions
    Last Post: January 9th, 2008, 12:10
  4. Skype
    By stuffradio in forum General Discussions
    Last Post: December 16th, 2006, 18:39
  5. Skype.com
    By niv in forum General Discussions
    Last Post: February 18th, 2005, 06:55
