Results 1 to 2 of 2
Thread: Error code 28, help needed urgently
    Junior Member kayeones is an unknown quantity at this point
    Apr 2012
    2
    Hello,
    My shop has been up and running for few weeks now. Today I wanted to add new product and here's what happened. I went admin/configure/categories/products and I see the following error:
    1 Can't create/write to file '/tmp/#sql_d3d_0.MYI' (Errcode: 28)
    in:
    [select c.categories_id, cd.categories_name, cd.categories_description, c.categories_image, c.parent_id, c.sort_order, c.date_added, c.last_modified, c.categories_status from categories c, categories_description cd where c.parent_id = '0' and c.categories_id = cd.categories_id and cd.language_id = '1' order by c.sort_order, cd.categories_name]
    If you were entering information, press the BACK button in your browser and re-check the information you had entered to be sure you left no blank fields.
    I checked my online shop to see how things are there and I see same code in the categories (I can see subcategories, but if I press on them I get same message). No products to view. here's my site just in case:
    lvbagsclassic.com
    Zen cart version 1.3.8b , and I haven't changed anything like coding, I added new products just yesterday and it was fine.
    Member storminternet has a little shameless behaviour in the past
    Dec 2011
    96
    This error occurs when there is no enough space in /tmp of the server. Please free up some disk space of /tmp or contact to your host to get this corrected.
    storminternet- UK's fully managed web hosting.
    Web Hosting Solutions | Cloud VPS |Managed Server Solutions
    ____________________________________________________________ _____
    Join the Storm Web Hosting Affiliate Scheme and get 20% of the sale value
Similar Threads
  1. urgently need help for file transfer error
    By breaker_82 in forum Computers
    Last Post: August 17th, 2004, 07:05
  2. Source code error
    By Loon in forum Webdesign / HTML
    Last Post: June 2nd, 2003, 08:55
  3. help needed urgently!!!
    By UndercoverHost in forum General Discussions
    Last Post: January 29th, 2002, 20:16
  4. php code error
    By coldturkey in forum Programming Help
    Last Post: December 21st, 2001, 14:41
