Could do with some help or advice here please.
Im working on a website that has meta data pulled from Curl feeds, whoever made it never left any instructions on how to manage the feeds, there`s 1000`s of lines of text in the feeds. I even copied a few of the page titles to find where it was in the feeds but never found any matches.
All the page`s are pulling in the header.php and the header is pulling in the Curl feeds.
Code:
<title><?php
if(isset($_GET['prod'])){
if(isset($catTree[0]['cat_name'])&&isset($catTree[1]['cat_name'])){
$vars = array ( "api_key" => "",
"subject" => $_SERVER["REQUEST_URI"].$catTree[0]['cat_name'].$catTree[1]['cat_name'].$_GET['prod'],
"file" => "",
"type" => $catTree[0]['cat_name'],
"label" => "",
"num" => 3,
"find_replace" => array("xx" => $product['prod_name'], "yy" =>$catTree[1]['cat_name'], "zz" => $catTree[0]['cat_name']),
"genTitle" => ''
$encoded_vars = http_build_query($vars);
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL,"");
curl_setopt($ch, CURLOPT_POST, 1);
curl_setopt($ch, CURLOPT_POSTFIELDS, $encoded_vars);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
$content = curl_exec($ch);
curl_close($ch);
echo $content;
else {
<?php if(isset($RSseo[$_GET['cat']])){echo $RSseo[$_GET['cat']]['title'];} else {?><?php echo $caseItem["title"]; ?><?php echo $newsItem["title"]; ?> <?=((isset($page) && isset($page["meta_title"]) && strlen($page["meta_title"]) > 0) ? $page["meta_title"] : $meta["meta_title"] ); }}?>
</title>
<meta name="description" content="<?php
#print_r($catTree);
if(isset($catTree[0]['cat_name'])&&isset($catTree[1]['cat_name'])&&isset($_GET['prod'])){
"file" => ($catTree[0]['cat_name']=='Used Furniture'?"usedMetaIndiv":"newMetaIndiv"),
"type" => "meta",
"label" => "",
"num" => 3,
"find_replace" => array("xx" => $product['prod_name'], "yy" =>$catTree[1]['cat_name'], "zz" => trim($catTree[0]['cat_name'])),
"genMetaDescription" => ''
$ch = curl_init();
curl_close($ch);
echo $content;
else {
if(isset($RSseo[$_GET['cat']])){echo $RSseo[$_GET['cat']]['metaDesc'];}
else { echo $caseItem["title"]; ?><?php echo $newsItem["title"]; ?> <?=((isset($page) && isset($page["meta_description"]) && strlen($page["meta_description"]) > 0) ? $page["meta_description"] : $meta["meta_description"] ); }
<meta name="keywords" content="<?php if(isset($RSseo[$_GET['cat']])){echo $RSseo[$_GET['cat']]['metaKeyw'];} else {((isset($page) && isset($page["meta_keywords"]) && strlen($page["meta_keywords"]) > 0) ? $page["meta_keywords"] : $meta["meta_keywords"] ); }?>" />
Rather than trying to work out all the code and piece together what goes where, I want to use another method. I remember working on another website that had a simpler method but I don`t remember how it was coded.
I need a method where I can pull in a file that I can use page id`s and specify the meta data for each page and I can re-write all the meta data as it`s not very good and most pages are keyword stuffed, the simple the better and preferably not database driven.
Any suggestions?
