Results 1 to 8 of 8
Thread: Zone Alarm causing problems
    Megalomaniac Daniel has disabled reputation Daniel's Avatar
    Oct 2000
    Montréal, Québec, Canada
    7,080
    I have no idea what to do, when I close Zone Alarm(normally when I shut down the computer), it gives me illegal operation messages. not 1 but 2!
    ZONEALARM caused an invalid page fault in
    module KERNEL32.DLL at 016f:bff7b983.
    Registers:
    EAX=ffffffff CS=016f EIP=bff7b983 EFLGS=00010206
    EBX=0127a9e0 SS=0177 ESP=01f4fbc8 EBP=02c40668
    ECX=02c40660 DS=0177 ESI=02c40668 FS=11ff
    EDX=bffc9490 ES=0177 EDI=02c40660 GS=113e
    Bytes at CS:EIP:
    80 3e 04 74 0f 33 c0 50 50 50 68 05 00 00 c0 e8
    Stack dump:
    02c40660 01262849 02c40668 00732c2c 02c40660 0083059c 01266f63 00833df0 00833df0 78863482 01f4fbf8 00830590 00833df0 7886265f 00000000 00830590
    and
    VSMON caused an invalid page fault in
    module VSMON.EXE at 016f:00417285.
    Registers:
    EAX=00000041 CS=016f EIP=00417285 EFLGS=00010206
    EBX=01f6fe28 SS=0177 ESP=01f6f4cc EBP=01f6f5f0
    ECX=ded92570 DS=0177 ESI=839bf130 FS=6c8f
    EDX=01450648 ES=0177 EDI=01f6f5d8 GS=0000
    Bytes at CS:EIP:
    8b 42 04 89 45 f4 8b 4d fc 89 4d f0 8b 55 fc 8b
    Stack dump:
    839fe308 00002983 575c3a43 4f444e49 535c5357 45545359 454b5c4d 4c454e52 442e3233 00004c4c 00000000 00000000 00000000 00000000 00000000 00000000
    I think it has something to do with the registry(I wont dare touch that though).
    In an everlasting search for low pings.
    Senior Member Super8 is an unknown quantity at this point Super8's Avatar
    Feb 2001
    214
    I'd suggest an uninstall then a re-install with latest version. Sounds like something went buggy. BTW: the new www.kerio.com firewall sems to be gaining popularity and kudos as the best free personal firewall.
    Oct 2000
    7,080
    I did reinstall it. No go...
    I'll try that..
    NL[C] Coolin is an unknown quantity at this point Coolin's Avatar
    Oct 2000
    5,259
    Check this post, there's many overlaps:
    http://www.freewebspace.net/forums/s...threadid=24470
    4 3 6 F 6 F 6 C 6 9 6 E
    Oct 2000
    7,080
    That doesn't really help.
    Anyways, problem fixed, I switched firewalls.
    Oct 2000
    5,259
    Both provided extremely cryptic error messages that mean absolutely nothing to anyone.
    Oct 2000
    7,080
    Ok.....then how do I fix it?
    While this topic is open, I can connect to the internet but once I'm connected, my connection dies, not disconnects, but just rather sits there and do nothing. I connect through ADSL..
    Btw, I'm using a different computer to connect to the internet but it's the same modem and isp so it must be a software problem.
    Pro Member [lhomme] is an unknown quantity at this point [lhomme]'s Avatar
    Jun 2001
    455
    On a related note - does anybody find that ZoneAlarmPro's ad blocker/privacy guard messes up the way pages are displayed?
