Results 1 to 5 of 5
Thread: Dial-Up Connection - Failed to establish connection
    I'm on a boat anhedonia is a name known to allanhedonia is a name known to allanhedonia is a name known to allanhedonia is a name known to allanhedonia is a name known to allanhedonia is a name known to allanhedonia is a name known to all anhedonia's Avatar
    Sep 2001
    Australia
    4,047
    I am having an issue with my Dial-Up connection. It dials in, it says it's connected and verifying username and password, then it says failed to establish connection and the box closes. I then have to open MSN or Opera and try connecting to a site or signing into MSN to make the Dial-Up box appear again, and the second time, although i haven't changed anything, I am dialled in perfectly fine. I am about 90% sure it isn't my provider, most likely a glitch on my computer, I am guessing. Any ideas?
    If it says 'Failed to establish connection', am I still charged for that phone call?
    Thanks!
    In all that we are losing
    Aren't we just confusing
    Youth with beauty?
    Truth with duty?
    Member Robert is a glorious beacon of lightRobert is a glorious beacon of lightRobert is a glorious beacon of lightRobert is a glorious beacon of lightRobert is a glorious beacon of lightRobert is a glorious beacon of light Robert's Avatar
    Oct 2000
    Kendall, FL
    5,834
    Re: Dial-Up Connection - Failed to establish connection
    Thanks!
    I haven't used a dialup connection in 3 1/2 years but it sounds like your ISP and not your computer.
    YourIP.us - Check your IP
    Checksite.us - Check if a site is down or not
    ReverseIP.us - Check how many sites are hosted on the same server.
    Forum Cleaner Jan has a reputation beyond reputeJan has a reputation beyond reputeJan has a reputation beyond reputeJan has a reputation beyond reputeJan has a reputation beyond reputeJan has a reputation beyond reputeJan has a reputation beyond reputeJan has a reputation beyond reputeJan has a reputation beyond reputeJan has a reputation beyond reputeJan has a reputation beyond repute Jan's Avatar
    Nov 2001
    NT Australia
    22,594
    Yes you are, once it gets to the verifying, you are charged. And yes it is your ISP. Give them a call and they might help you configure your "extra" settings.
    Junior Member Hungarian is an unknown quantity at this point
    Sep 2003
    France
    9
    It is your ISP. I had it with Freeserve in England and it drove me nuts...
    Do you get disconnected regularly?
    <*j*>Crazy Hungarian<*j*>
    Pro Member 98125 is an unknown quantity at this point
    Apr 2002
    UK
    267
    im a freeserve dial up user and find the same problems - if i just shut down the computer and leave it off for a minute, switch it back on and it works for me
    Mullin
