Results 1 to 9 of 9
Thread: Browser Help!
    Member Dark Tribe is an unknown quantity at this point
    May 2001
    40
    Browser Help!
    Hi All
    I`ve noticed over the past 2 days that my Browser IE 5.5 isn`t working right, it works fine for a while and then when paging and calling up sites I get missing icons and pictures, plus it sometimes doesn`t get there, but when I use AOLs browser on the same connection all is fine, any ideas?
    *©*´¯`·-· Dean ·-·´¯`*©*
    NLC Bruce is a glorious beacon of lightBruce is a glorious beacon of lightBruce is a glorious beacon of lightBruce is a glorious beacon of lightBruce is a glorious beacon of lightBruce is a glorious beacon of light Bruce's Avatar
    Dec 2000
    Maine
    12,147
    well since aol's browser is a form of ie i don't really know. maybe try reinstalling?
    NLC lucifer is an unknown quantity at this point lucifer's Avatar
    Mar 2001
    Hades
    1,213
    I had a similar problem but getting a new ISP seems to have solved it
    };-P
    stuff -->---------------
    Dec 2000
    Maine
    12,147
    aol ain't that bad. i use them but only becuase they're so cheap.
    Nice Shot cowax is just really nicecowax is just really nicecowax is just really nicecowax is just really nice cowax's Avatar
    Nov 2000
    1,079
    Get IE 6
    Dec 2000
    Maine
    12,147
    ie 6 is nice. i've benn usin it for about a month and hasn't crashed once.
    Nov 2000
    1,079
    Its ok... I personally think it has too much crap on it. When I click on a link to veiw a media file or whatever, I expect Media Player to popup, but instead its on the side of the browser and me with a slow comp, it gets quite annoying
    Doot Do Do Do bigperm is a name known to allbigperm is a name known to allbigperm is a name known to allbigperm is a name known to allbigperm is a name known to allbigperm is a name known to allbigperm is a name known to all bigperm's Avatar
    Apr 2001
    mmmhmmm
    3,033
    I was having similar problems, and I have AOL. I think that it is just AOL ----ing up. You can fix it (kinda) by repairing IE.
    Aol also offers broadband... it's called 'high speed crap'.
    Getting cable in June.
  9. #9
    ლ(╹◡╹ლ) LeX has disabled reputation
    Oct 2000
    7,596
    Get IE 6. Disable stuff you don't want, and it's pretty much the same as IE 5.5, except it doesn't crash as much.
