January 23rd, 2005, 07:35
#1
Pro Member
January 23rd, 2005, 07:57
#2
For starters, what OS are you running..
and then how much ram, and what type of CPU do you have...
the problem is most likely that your cd drive is in PIO mode, which is CPU intensive, you want to switch that mode to UDMA (doesn't matter what mode, but it should be 2), to place the load on ram instead.
Google it if you want, or reply back here.
January 23rd, 2005, 09:33
#3
striking reality
January 25th, 2005, 08:08
#4
Pro Member
Windows XP, 512MB of RAM, centrino 1.5G
the drive is part of a Sony notebook CRX950E,and sometimes it plays with fewer pauses even with the same disk
how do I find out the PIO mode, I looked in the device manager under the CD-ROM, but I couldn't see anything
January 27th, 2005, 23:17
#5
google for how to set 'dma mode' - it should turn up a few user friendly tutorials...
January 28th, 2005, 06:19
#6
Pro Member
I found a page
http://www.helpwithwindows.com/WindowsXP/howto-05.html
apparently by computer was already set up to use DMA if available
and they were running on Ultra DMA 2 and 5.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
